99 deville oil pump
Results 1 to 15 of 15
Northstar Engines and System Technical Discussion Discussion, 99 deville oil pump in Cadillac Engine Discussion; Hey so apparently the oil pump in my dads 99 Deville has gone, the mechanic said it costs about the ...
    Enano is offline Cadillac Owners Member
    Automobile(s): 99 Deville
    Jan 2008
    22
    99 deville oil pump
    Hey so apparently the oil pump in my dads 99 Deville has gone, the mechanic said it costs about the same do drop in a new engine as it does to replace the oil pump so thats what he wanted to do.... Load of crap? Ive done a little engine work before, anyone have anything to say on the matter? Any documents detailing the procedure?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Re: 99 deville oil pump
    The oil pump on the N* is wrapped around the crankshaft snout, inside the front chaincase. It can be replaced from the wheelwell area, but it's pretty labor-intensive. The mechanic needs to follow the GM Service Manual procedure. Crank balancer bolt torque is critical to proper oil pump operation.
    If the oil pump went out, did the engine seize ? If so, it's new/rebuild engine time.
    You could subscribe the car to www.alldatadiy.com to see what you're up against, and the subscription will come in handy dozens of times.......
    Jan 2008
    22
    Engine has not seized yet. So the engine doesn't need to be pulled for this? Thanks for the link I'll check that out. I've decided against putting my extra 5.7L Hemi in. She isn't fond of FWD
    Talamant3z's Avatar
    Talamant3z is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Eldorado
    Jun 2008
    637
    damn sounds like alot of work. do oil pumps go out easy
    69
    82,383
    Nope.
    Feb 2006
    57,139
    Hmmmmmmm.......What gives you or your mechanic the impression that the oil pump has packed it in ??? IF there's a flickering oil pressure light at idle, there may be a very simple solution.........
    Jan 2008
    22
    What could this easy solution be. Im not around the car, I'm in school in another state. Ill ask him if its a light at idle
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Higher weight oil was the simple solution I believe... I'm not positive if that was what Sub had in mind though.
    69
    82,383
    The oil pumps are pretty reliable. I suspect what Sub was getting at it the oil pressure switch on the oil filter adapter. You could either plumb in a pressure gauge and see what your oil pressure actually is or just take a chance and swap in a new switch. That would be much cheaper and easier than replacing a pump.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Ranger and Sub are right - usually, it's the oil pressure switch - cost under $10, so personally, I think it's easier to replace it than to bother setting up a gauge.
    If the oil pump is shot - pretty unusual, you will need to take off the crankshaft damper/pulley, timing case cover, and I think drop that side of the cradle down some for access. I can't remember where the pump is in relation to the crank to intermediate gears and chain - that stuff might have to come off also.
    aac123 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville DTS
    Oct 2008
    102
    its really not that bad,oil pump is only 3 bolts, remove accesory belt(the big one) take off whatevr is blocking timing cover(i think a tensioner or maybe idler bearing) then the acces panel on pass wheel well. Remove 3 cradel bolts, lock the flywheel and remove crankshaft bolt, then the pulley with 3 jaw puller. Remove the 15 bolts(10 MM) on timing cover.Pull timing cover and oil pump is right there with 3 bolts. When reinstalling be sure to tighten 89 in. pounds in sequence then torque an additional 35 degrees in sequence. Sequence is middle bolt first, right bolt second and left bolt 3rd.
    hope that helps and good luck!
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Quote Originally Posted by aac123 View Post
    Piece of cake
    RickyHenry's Avatar
    RickyHenry is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville; 1999 Seville
    Mar 2008
    134
    Wouldn't you have to drop the engine for that?
  16. #14
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    Quote Originally Posted by RickyHenry View Post
    I don't see why - there have been several people that have done HG's with the engine in the car and have opened the timing cover to set the timing.
    Having said that, I wouldn't want to do it - seems like it would be an incredible PITA to do in the car, but some people are just gluttons for punishment.
  17. #15
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Drop the right side of the cradle down enough for access - lost of other things also - I think that's a pretty big deal, but it's not for some people - getting old I guess
  18. Remove Advertisements
