Do NS engines have an "air regulator"?
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Do NS engines have an "air regulator"? in Cadillac Engine Discussion; I went to a car service a week ago ... and they told me that the "air regulator" needs to ...
    SoWorriedDriver is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    38
    8
    I went to a car service a week ago ... and they told me that the "air regulator" needs to be replaced ...
    I searched this forum with "air regulator" keywords but found nothing..
    Does NS engine has an air regulator? and if there is .. what are the symptoms of a faulty one?
    devill 98
    thank you so much..
    STSS is offline Cadillac Owners Enthusiast
    Automobile(s): '03 STS 122K, '01 STS 161K - 3/3/11
    Apr 2008
    Grafton, Ohio
    32
    671
    Re: Do NS engines have an "air regulator"?
    Did they say it was on the engine? Are you located outside the US? Could it be suspension related?
    Aug 2008
    38
    8
    Thank you STSS,
    I don't know, It doesn't shift to lower gears easily, and it is bogging so bad. they say you need to change the air regulator. is there an air regulator in these engines? and are these the symptoms of a faulty "Air Regulator"?
    And yes, i'm in the Middle East, Bahrain.
    I don't know if it is the suspension.
    68
    81,922
    Never heard of an "air regulator". Might want to get some clarification from them. I'm sure they are using a non conventional term.
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    34
    963
    Pull your codes, pass temp up + ac OFF button for about 5 seconds with the ignition in the 'on' position (engine doesn't have to be running)...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    I'll bet you dollars to doughnuts that the Bahrain car tech is referring to the old "vacuum modulator" which controlled full and part- throttle shifts in older transmissions.
    Read up on pulling the Diagnostic Trouble Codes for your car......at the top of these main pages: "How to pull codes". You want the system for OBD-II.
    If you find a code which refers to TCC or TCC Stuck Off, do some searching in here and Cadillac Technical Discussion or Northstar Performance. DON"T let the repair shop into the transmission yet !!!!
    Aug 2008
    38
    8
    Thank you guys,
    I'm sorry for not giving much details, making you guess.
    I'm not quite good at technical terms at all. even non-technical terms.
    Ranger, I expected to see your reply to "my" thread. Thank you so much. and yes they might used different terms.
    However guys, I didn't get much details from them. it was hot and humid outside at noon.
    The car doesn't start fast. and the RPM goes up and down. and it stalls or bogs (don't know if there is much difference between those 2 terms and which one is the right one) however, when I press the accelerator pedal.. it hesitates..
    There is no gas smell at all.
    Thanks to Raze and submariner409 .. I got the codes:
    p0322
    p1660
    b 2150
    they are current.. don't know if I did a good job in pulling these codes... or if they related..
    and I'm sorry again for not giving proper details from the first.
    Aug 2008
    38
    8
    sorry.. I think I should search for those codes using the search engine above as submariner409 said ... Thank you guys.
    Feb 2006
    55,904
    Don't ever worry about asking questions in Cadillac Forums. The more we all ask and answer, the more we know. Sometimes, answers to a problem that has been discussed at great length can be a bit tedious, but everyone benefits in the experience shared. Yes, we all get on our High Horse once in a while, but that's the "dammit factor", nothing else.
    68
    81,922
    The car doesn't start fast. and the RPM goes up and down. when I press the accelerator pedal.. it hesitates..
    Check the fuel pressure.
  13. Remove Advertisements
