96 Eldo ETC I found the ABS computer cover...how do I get in it?? Do I force it?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 96 Eldo ETC I found the ABS computer cover...how do I get in it?? Do I force it? in Cadillac Engine Discussion; Hey all This one has been fun. Code TC0027, Front drivers hub. I replaced it and still have the same ...
    thebossman's Avatar
    thebossman is offline Cadillac Owners Member
    Automobile(s): Cadillac 96 ETC
    Nov 2007
    31
    Hey all
    This one has been fun. Code TC0027, Front drivers hub. I replaced it and still have the same problem. I've metered the leads at the fire wall connections and have 4.5 volts on the passenger side constant and 4.5 volts on the drivers side intermitent. I want to test the connections at the ABS, and replace it if nessecary. I've found the cover, but I'm having troubles getting into it.
    cancuncaddy is offline Cadillac Owners Member
    Automobile(s): 1996 ETC
    Sep 2009
    54
    40
    Re: 96 Eldo ETC I found the ABS computer cover...how do I get in it?? Do I force it?
    Lift the small stainless steel clip assembly by doing so the back part of the connector will raise slightly, to lift in that direction (up) when the connector is at about a 30 degree angle gently pull the connector towards the rear of the car and it will come loose! Be carefull re- connecting!
