95 seville died and wont start
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 95 seville died and wont start in Cadillac Engine Discussion; I have been told that there is a oil pressure sensor that is associated with the fuel pump that will ...
    RayL is offline Cadillac Owners Member
    Automobile(s): 1995 seville sls
    May 2009
    63
    3
    Unhappy95 seville died and wont start
    I have been told that there is a oil pressure sensor that is associated with the fuel pump that will shut down the fuel pump if the oil pressure drops. If this is true can you tell me how to find and test this oil sensor?
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: 95 seville died and wont start
    Why are you immediately going after the oil pressure sensor?... Did a message come up on the dashboard saying "LOW OIL PRESSURE", "SHUT OFF ENGINE"? that's what that sensor would put up if it was seeing low oil pressure... What codes are you getting? Is the engine even turning over?
    Sorry about the barrage of questions but we just need more information in order to point you in the right direction.
    68
    81,889
    Have you checked the fuel pressure?
