Vacuum line routing?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Vacuum line routing? in Cadillac Engine Discussion; I need some help figuring out what goes where on this 96 intake manifold... I labeled all the ports A-F ...
    Feb 2004
    FL
    2,250
    I need some help figuring out what goes where on this 96 intake manifold... I labeled all the ports A-F in these 2 pics here. Also, is it correct that the port labeled "E" should be connected to the FPR? On my 95 manifold, it was connected to "C"... Any help is appreciated. Thanks,
    Feb 2004
    FL
    2,250
    Re: Vacuum line routing?
    aaaaaaany ideas ladies?
    69
    82,383
    A - Left bank (front) cam cover right (passenger) side
    B - PCV valve
    C - Evap canister purge valve (port next to electrical connection, right bank cam cover)
    D - Power brake booster
    E - FPR
    F - runs to what appears to be a check valve? then to a "T" fitting then thru the firewall on the passenger side.
    Feb 2004
    FL
    2,250
    Quote Originally Posted by Ranger
    B - PCV valve
    E - FPR
    Okay, thanks for your help!
  7. Remove Advertisements
