Gear Shift Position Indicator 1994 STS
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Gear Shift Position Indicator 1994 STS in Cadillac Engine Discussion; The Red indicator position indicator on the gearshift on my 1994 STS does not indicate the right gear.It will be ...
    Duncan101 is offline Cadillac Owners Member
    Mar 2004
    3
    The Red indicator position indicator on the gearshift on my 1994 STS does not indicate the right gear.It will be off center or while I select drive it would be between at an angle between drive and neutral the open end visible pointing up to neutral on the drivers side.If i move the gearshift around it can be corrected but will do it again.This happens when I select other gears as well.Is something broken or can I remedy the problem myself without pouring out a lot of money.Any advise or help in this matter would be appreciated.
    Thanks
    John
    Pjs's Avatar
    Pjs
    Pjs is offline Cadillac Owners Fanatic
    Mar 2004
    Nashville, TN
    367
    Re: Gear Shift Position Indicator 1994 STS
    I'm not sure if the 94 & 95 have the same type of shifter set-up, but mine did the same thing. Once I got the assy. out, I found that the red indicator is a piece of plastic with 2 pins which go through the sliding metal strip. One of the pins is broken allowing the indicator to pivot. The sliding metal strip on mine had a couple extra holes in it (Still can't figure that one out) so I just pulled it out till I can get another one
    Patrick
    Mar 2004
    3
    Thanks Patrick will take a look inside once i have it removed.
    John
    caddyshack24's Avatar
    caddyshack24 is offline Cadillac Owners Enthusiast
    Mar 2004
    Florida
    36
    599
    http://www.gmotors.com/
    They want $61.80 .. mine was shifting out of place, finally disappeared.
  7. Remove Advertisements
