94 SLS Radiator
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 94 SLS Radiator in Cadillac Engine Discussion; My normal engine temp is 217. I know that is too high as i have a new pump and thermostst ...
    Jim Gale is offline Cadillac Owners Member
    Jun 2003
    charlotte NC
    4
    94 SLS Radiator
    My normal engine temp is 217. I know that is too high as i have a new pump and thermostst i assume a new radiator is in the offing. I would appreciate some input as to the specs i should look for in the replacement and a reliable source. Is the replcement on the SLS as routine as it is on many cars? Anything else i should check before i order a replacement Thanks Jim
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: 94 SLS Radiator
    Quote Originally Posted by Jim Gale
    That is NOT too high. It's actually quite normal.
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: 94 SLS Radiator
    217 is fine, most cars around here run at 220 or so (except mine, good ol 176!!)
    Jun 2003
    charlotte NC
    4
    Thanks guys thats a reliefe. the reason i thought it ws too high is that i had an NS engine that ran at 207 normally Jim
  7. Remove Advertisements
