95 SLS throttle body vacuum plug
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, 95 SLS throttle body vacuum plug in Cadillac Engine Discussion; Looking for the 3 way rubber grommet replacement. The piece that connects the vacuum hoses to the top of the ...
    clampet is offline Cadillac Owners Member
    Automobile(s): 1995 Seville SLS
    Dec 2008
    3
    The piece that connects the vacuum hoses to the top of the throttle body.
    Anyone one knows of an after market piece. Mine is cracked and leaking and brittle.
    Thanks in advance,
    Jed
    js94sts is offline Cadillac Owners Member
    Automobile(s): 94 cadillac seville sts
    Mar 2009
    Re: 95 SLS throttle body vacuum plug
    hey i been looking for the same piece and no luck yet
    eric007's Avatar
    eric007 is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado Convertible
    May 2005
    Midlands of SC
    54
    19
    Hi,
    Did anyone ever find this piece? I need a replacement also, but can't find it. Thanks.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    I ended up using some ultra black RTV gasket maker on mine. Works fine, but it may only be a temporary fix.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    Take a look at the "Help !" blister pack rack at your local large parts store. There are any number of fittings, connectors, vacuum hose - so many that you can make your own custom vacuum "tree".
    Bigdadcad is offline Cadillac Owners Member
    Automobile(s): 95 Eldorado, 2002 Escalade
    Aug 2008
    11
    Same problem here.
    I checked with my local GM dealer. The part you are looking for comes in a kit with tubes, a regulator and solenoid. It is GM Part # 03539219, HARNESS, EVAP EMIS CNSTR PURGE (INCLS 2-6). My discount price was $125, wholesale about $145. They don't just sell the vacuum port connection. I suggest your local salvage yard. Also check the other rubber connection at the solenoid.
    I don't know how much a leak here would affect performance since it is tied into the evaporator purge system. Probably not much, if at all, except for a burp at startup. Hopefully others can comment. Ranger, you out there?
    69
    82,386
    I would not think that would affect performance too greatly either.
    Feb 2006
    57,148
    The problem with a leak in the EVAP system is that it sets the "Check gas cap" message and then eventually sets EVAP codes which will fail emissions testing. EVAP only purges the fuel vapor overflow canister under specific cruise conditions when a small amount of extra "air leak" will not upset fuel mixture calculations, so a full-time vacuum leak is not good.
    m0ng0 is offline Cadillac Owners Member
    Automobile(s): 1993 Allante, 1973 Eldorado Convertible
    Apr 2007
    Battle Ground, Wa
    46
    42
    sorry to bump this, I just broke mine last night, any solution other then making your own?
    Feb 2006
    57,148
    Post #5. Necessity is the mother of invention.
    Probably so obsolete you would never find a new exact replacement. Any of those vacuum lines/pipes/connectors can be replaced with parts from the Help! racks at any large parts store.
  13. Remove Advertisements
