where can i find a 4.6 northstar engine for a 94 eldorado touring coupe. vin 9
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, where can i find a 4.6 northstar engine for a 94 eldorado touring coupe. vin 9 in Cadillac Engine Discussion; my motor caught on fire for no apparent reason. i turned the key and my manifold popped off of my ...
    sinclairtay is offline Cadillac Owners Member
    Mar 2004
    pittsburgh pa
    19
    Unhappywhere can i find a 4.6 northstar engine for a 94 eldorado touring coupe. vin 9
    my motor caught on fire for no apparent reason. i turned the key and my manifold popped off of my car and burnt. my injectors were burned and the black plastic pipes burned real bad to but nothing elsed burned up. do i keep the motor or should i put another one in it.
    Feb 2004
    FL
    2,250
    Re: where can i find a 4.6 northstar engine for a 94 eldorado touring coupe. vin 9
    from your description, it sounds like your motor is okay? There's an intake for a 94 on ebay right now... I personally would pick that up and drop it on.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    The motor is likely fine. Just replace the intake. Remove the center 4 bolts to remove the intake and replace it. Sounds like there may have been a fuel leak from the fuel pressure regulator rupturing or something like that inside the manifold.
