Stalling when wet
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Stalling when wet in Cadillac Engine Discussion; Hello, I am actually having two issues right now, and I am not sure if they are related. I drive ...
    krame36 is offline Cadillac Owners Member
    Mar 2006
    3
    Stalling when wet
    Hello, I am actually having two issues right now, and I am not sure if they are related. I drive a '98 SLS and it has been stalling when it rains. I also just pulled a P1652 code off of it. Does anyone have any ideas? Thanks for the help.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: Stalling when wet
    P1652 - Powertrain Induced Chassis Pitch Output Circuit Probably not related. Clear it and see if it returns. Wet stalling is most likely spark plug wires and/or coil packs. Open the hood and mist some water from a spray bottle in the engine bay at night. The results of that test should point you to the problem.
    Mar 2006
    3
    I actually replaced all of the spark plugs and wires at the end of last summer thinking that was the issue, but during our last rain storm here it stalled twice again...any other pointers?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Check your plug wiring against the diagrams and check the coil towers for excess dust, oil, or carbon tracks. Even a small amount of humidity in a loose or tracked coil tower will cause a miss.
    Has anything been done to the engine air intake system that would allow excess moisture into the throttlebody or manifold ?
    Apr 2007
    The Ocean State
    53
    3,516
    Coil pack(s) would be next on my list.
  8. Remove Advertisements
