1998 STS : Code v
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 1998 STS : Code v in Cadillac Engine Discussion; My 1998 STS runs fine, while at idle for a long time the check engine light comes on, I pulled ...
    jevanof's Avatar
    jevanof is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Sep 2007
    212
    1998 STS : Code v
    My 1998 STS runs fine, while at idle for a long time the check engine light comes on, I pulled the codes and got P0300. I does not ever seem to idle ruff.
    just some history, I changed the Head Gasket last year. and I replaced the spark plugs and hoses, I did not change the coil packs and think that might be next.
    Any Ideas?
    68
    81,887
    Re: 1998 STS : Code v
    Did you change the plug wires? If not, that's what I'd change next (A/C Delco).
    jevanof's Avatar
    Sep 2007
    212
    i will do that today,
    is there a way to test the coil pack? they cost $100 and dont want to spend that unless I have to
    68
    81,887
    You can pull the coils and look for signs of arcing at the plugs or listen to them with a rubber hose for arcing. I think you can test the resistance, but I'm not sure what it should be.
  7. Remove Advertisements
