Cranshaft Main Bolts
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Cranshaft Main Bolts in Cadillac Engine Discussion; I'm going to reseal the block halves while I have the motor out. Can the crankshaft main bolts be reused? ...
    spin's Avatar
    spin is offline Cadillac Owners Member
    Automobile(s): 1999 Seville STS
    Mar 2009
    33
    I'm going to reseal the block halves while I have the motor out. Can the crankshaft main bolts be reused? I read the TSB and it mentions nothing about using new ones.
    Also is a new oil distribution plate really required?
    Is there an equivalent to the gm sealant P/N 88861417 that is readily available at an auto parts store?
    Thanks for all the help. Just looking for some advice/knowledge from people that have already done this.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Cranshaft Main Bolts
    I read somewhere that once those bolts are removed, you should "insert" all the holes. I think the bolts are re-usable. I think the new plate is recommended. My half case was not leaking when I did my HG project, so I left the half case alone - just changed the rear main seal and pan gasket, both of which WERE leaking.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by spin View Post
    Use only the GM sealer. It is a bonding/epoxy type
    http://www.cadillacforums.com/forums...v-sealant.html
    69
    82,161
    I don't believe you can reuse the bearings either.
    spin's Avatar
    Mar 2009
    33
    Unless this northstar motor is different than just about any other motor made, I should be able to reuse the bearings as long as they stay in the journal.
    69
    82,161
    I recall our old Guru saying something about a crush factor and once they are unbolted they should never be reused. I think he was talking about the rod bearings, but I believe the same goes for the mains.
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Yes - you should not re-use the bearings
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    GM says that you can reuse both the Rod and Main brgs
    GM also says to replace the Rods brgs every time. Older info
    Most techs reuse the mains. I had a claim bounced because I had a set of mains on the RO. "Excessive Parts"
  11. Remove Advertisements
