Swap 4.9l v8 and 4.6l v8 northstar
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Swap 4.9l v8 and 4.6l v8 northstar in Cadillac Engine Discussion; I have a 1994 Cadillac seville with a 4.6l v8 northstar and the engine went (head gasket leak) and was ...
    rellsun is offline Cadillac Owners Member
    Automobile(s): 1994 Seville SLS
    Jan 2009
    25
    10
    QuestionSwap 4.9l v8 and 4.6l v8 northstar
    I have a 1994 Cadillac seville with a 4.6l v8 northstar and the engine went (head gasket leak) and was wandering if a can swap it out with a 1993 deville 4.9l v8?
    69
    82,171
    Re: Swap 4.9l v8 and 4.6l v8 northstar
    No. Different trans. Different PCM. Probably motor mounts and other things I'm not thinking about.
    Destroyer Guest
    Dude just get another car.
    CaptainFishpond's Avatar
    CaptainFishpond is offline Banned
    Automobile(s): 99 DeVille (Grace Slick)
    Jul 2006
    Cleveland
    31
    333
    Drop in an LT1!
    Highline Cady's Avatar
    Highline Cady is offline Cadillac Owners Fanatic
    Automobile(s): Nitrous03DHS,AJtune,Corsa,Volant,3.71s,Grille,tinted,stall'd
    May 2007
    Wisconsin
    40
    305
    Why why why if your going through the hassle of switching to a different motor would you ever pick a 4.9? Swap a fwd Impala SS running gear, it'd probably be easier. Personally just stick another N* in it and do basic maintenance and you probably wouldn't be in this situation to begin with.
    801Hill's Avatar
    801Hill is offline Cadillac Owners Fanatic
    May 2005
    West Valley City, Utah, United
    34
    122
    I think that it would be possible but it would be alot of work and you would run into alot of problems. I think that it would be less work to fix the Northstar. If your up to swapping engines out then you should be able to tackle the HG. I just finished my first HG/headbolts project, biggest job I ever did but I finished it and it works! even with a few extra bolts left over lol. That always happens to me.
    Dont get me wrong I love the 4.9, it always amazes me how much power it has and it will run to 200,000+ miles with no major problems unlike the Northstar HG. The problem is the 4T60E that it is mated to. You will go through 2 of them for every 4.9 engine.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    I have seen a lot of 4.5L & 4.9L Head Gasket failures, so what would the advantage be?
    Jan 2009
    25
    10
    Well i was going to have a friend do the work and he said its best to get a rebuild or one in good running condition instead of getting a junkyard one. so i saw a 1993 deville with a 4.9 on craigslist for 600 compared to 1000-2500 for a junkyard or rebuilt motor. Anyway didn't think it would work but doesn't hurt to ask.
  11. Remove Advertisements
