heater on bench 1?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, heater on bench 1? in Cadillac Engine Discussion; i have changed the oxygen sensor 1 of bench1, like 3 times, and always present the same code, HEATER SENSOR ...
    carloslara is offline Cadillac Owners Member
    Automobile(s): deville DHS
    Feb 2009
    Santo Domingo, Dominican Repub
    37
    16
    heater on bench 1?
    i have changed the oxygen sensor 1 of bench1, like 3 times, and always present the same code, HEATER SENSOR 1 BENCH 1.i have inspect the line, and the heater power line, negative and positive, + the signal and ground, are good from the pcm. at least on the end connector to the A/F sensor.
    how i can solve this matter?
    68
    82,056
    Re: heater on bench 1?
    I think you mean Sensor 1 BANK 1. Are you using an A/C Delco sensor?
