94 STS Coolant leak between block and flywheel
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 94 STS Coolant leak between block and flywheel in Cadillac Engine Discussion; Coolant system full, engine off, cap off, coolant dripping down from between flywheel and block; can not see origin of ...
    chucktaylor is offline Cadillac Owners Member
    Jun 2006
    5
    Coolant system full, engine off, cap off, coolant dripping down from between flywheel and block; can not see origin of leak from below or above. Anybody know from where it might be comming?
    69
    82,402
    Re: 94 STS Coolant leak between block and flywheel
    Crossover manifold would be my guess.
    Jun 2006
    5
    Thanks Ranger. Looking at ewill3rd's photos I think I'll need a keg for this job.
