EGR symptoms
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, EGR symptoms in Cadillac Engine Discussion; What are the symtoms of a sticking egr, car is surging a little new coils could possibly be a fouled ...
    TN Torando is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado
    Jan 2009
    47
    21
    EGR symptoms
    What are the symtoms of a sticking egr, car is surging a little new coils could possibly be a fouled plug, fuel injector, egr and suggestions.
    68
    81,889
    Re: EGR symptoms
    A stuck open EGR will stall the engine at idle.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,847
    Re: EGR symptoms
    Another symptom of a sticky EGR valve is a brief, minor ignition "rattle" on part-throttle acceleration or a low pitched ignition ping during moderate part-throttle such as going up a slight grade. And, as Ranger said, a partly open EGR will trash the idle characteristics.
    It is entirely possible that a surge could be present also, as when EGR operates it dilutes the incoming air (oxygen) charge in order to control combustion temperatures: excess exhaust gas from a fluttering EGR would upset the fuel/air mixture.
