Time Serts, Norm's, SureGrip Stud Kit?????? - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 55 of 55
Like Tree5Likes
Northstar Engines and System Technical Discussion Discussion, Time Serts, Norm's, SureGrip Stud Kit?????? in Cadillac Engine Discussion; how do i get norms inserts? and what is the difference between norms and jakes??...
  1. #46
    lynbr's Avatar
    lynbr is offline Cadillac Owners Member
    Automobile(s): 1998 cadillac deville
    Mar 2012
    24
    9
    Re: Time Serts, Norm's, SureGrip Stud Kit??????
  2. #47
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Norm's are threaded inserts that go into the block that original style head bolts screw into... Jake's design are studs tat you put into the block and you use nuts to fasten the heads down.
  3. #48
    lynbr's Avatar
    Mar 2012
    24
    9
    so whose are better? and whose are more difficult to install?
  5. #49
    eyewonder is offline Cadillac Owners Fanatic
    Automobile(s): 2000 STS, 200K Miles
    Nov 2011
    SE Kansas
    68
    187
    Who's package is more difficult to install?
    I just finished drilling & taping my block for Norm's inserts, but have never done Jake's. I have read Jake's procedure posted on his web site, and seen pictures. Both do utilize the same general procedure: use a jig fixture (centered over the old hole) to drill out the old threads in preparation for taping for inserts/studs. After each hole is drilled, a bushing for the tap is installed in the jig, and the hole is taped, by hand. You do this for all 20 bolt holes. The procedure for Norm's then calls for applying lock-tite to the insert & threads in the block, and inserting to a specific depth. Jake has a procedure that is specific to the dimensions of his studs.
    I elected to go with Norm's inserts - because I could get them! I also chose to go with ARP studs in Norm's inserts. If you do that, let him know, as there is a slight difference in inserts when using new GM head bolts, or the ARP studs. The combo of Norm's inserts & ARP studs ended up being approximately $100 more that Jake's package.
    Having done only 1 of the two procedures, but read the other, it seems that the actual work for either would be the same.
    Information on Norm is at: www.HuhnSolutions.com . The studs are ARP part # 141-4204 (for Dodge SRT4 & PT Cruiser), and you will need two of the stud packages.
    Cheers,
    Steve
  6. #50
    68
    82,058
    Quote Originally Posted by lynbr View Post
    so whos are better? and whos are more difficult to install?
    6 of one, half dozen of the other. As mentioned, installation is about the same.
  7. #51
    angeno is offline Cadillac Owners Member
    Automobile(s): 1999 Deville
    Sep 2011
    56
    14
    Wonder if anyone in the forum might know of a service provider in the Phoenix, AZ area who is competent and experienced in performing the Sure Grip stud kit restoration.
  8. #52
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,197
    Call or e-mail Jake. www.northstarperformance.com
  9. #53
    04GrandAmGT's Avatar
    04GrandAmGT is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS, 04 Grand Am GT,07 Cobalt(Dont Judge,My fuel Saver)
    Oct 2012
    Manitoba, Canada
    376
    Evrett Here, i will look into our files and see if i am able to locate a shop approved by us.
  10. #54
    ridinginstyle is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Seville STS
    Oct 2013
    40
    40
    Why does no one recommend the GM recommended Time Sert product? Is it not good? I thought it would be the way to go.
  11. #55
    Feb 2006
    56,197
    You seem to be having a good time resurrecting old, dead threads from past history. There is a LOT more, later info on BigSerts, Norm Huhn's NS300L inserts and the SureGrip studs from NorthstarPerformance.
    The original TimeSert (Time Fastener Corp.) for the Northstar head bolt replacement size was replaced by their BigSert quite a while back - for the same reasons the NS300L is/was the superior product.
  12. Remove Advertisements
