PO155 (HO2S) Code
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, PO155 (HO2S) Code in Cadillac Engine Discussion; Can any one tell me what this code means and where it is on the bank 2 (radiator side)? What ...
    jerry23 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    24
    PO155 (HO2S) Code
    Can any one tell me what this code means and where it is on the bank 2 (radiator side)? What function does it perform? Is it hard to replace?
    P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1
    68
    81,917
    Re: PO155 (HO2S) Code
    Yeah, that's the radiator side. Just like changing a spark plug, but you need a special socket for it. It measures the oxygen in the exhaust and reports it back to the PCM so that it can keep the fuel at a stoichiometric value.
    Aug 2007
    24
    Thanks
