Fuel Pump removal
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Northstar Engines and System Technical Discussion Discussion, Fuel Pump removal in Cadillac Engine Discussion; All the 1999 STS manual says I need a collar ring removal tool to get the fuel sending assembly out ...
    planocolt is offline Cadillac Owners Member
    Automobile(s): 1999 sts
    Dec 2008
    65
    Fuel Pump removal
    All the 1999 STS manual says I need a collar ring removal tool to get the fuel sending assembly out of the tank.
    Does anyone have a work around?
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: Fuel Pump removal
    You should probably post this in the Seville/Eldo forum. The job can be done without the tool from what I have seen posted but you need to be careful about pounding the ring out. You will also need a new gasket.
    Apr 2007
    The Ocean State
    53
    3,516
    Dec 2008
    65
    Yea, I guess that would make more sense. Anyone have this tool for sale:
    68
    81,916
    I've used an hammer and a screwdriver and just tapped the retaining collar (ring) to turn it.
    Dec 2008
    65
    Were you not a little concerned about sparks....?
    68
    81,916
    Nope. The tank was still sealed until I loosened it. Putting back on was the same. Had it finger tight, then by the time I had to tap it in place, it was sealed. Besides I WAS careful when tapping it on and off.
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    If your concerned about sparks you could use a brass drift instead of a screw driver.
    68
    81,916
    Correct. I wasn't worried about sparks though.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Out of the hundreds I have done I have used many methods and never had a concern of sparks.
    It isn't really a spark generating process.
    Be sure to have something handy, like a fire extinguisher just in case but....
    Dec 2008
    65
    I always have a fire extinguisher (or two) around.
    Cause I tried to burn my Cadillac to the ground once........
    Dec 2007
    Ledyard, CT
    57
    299
    Quote Originally Posted by planocolt View Post
    Please share
    68
    81,916
  16. #14
    Dec 2008
    65
    Oh yea, that was fun, I will post pics once I get the car running again, It's fuel pump time. I received the assembly yesterday. Jeeze, it's Huge
  17. #15
    Dec 2008
    65
    OK, the lock ring wasn't a big deal at all. Fuel pump replaced.
    Car starts now but I still have the same issue I started with I cannot throttle up and she stalls (And the overpressure valve pops). Throws code P0101.
  18. Remove Advertisements
