Results 1 to 2 of 2
Thread: Service Emissions System
    Phoenix
    39
    31
    Question Service Emissions System
    I have a 96 Sedan Deville that has a Service Emmisions system coming across the DIC. When I put it on the scanner the only code coming up is P0325 which indicates KNOCK SENSOR circuit. I replaced the sensor and the emissions light is still on along with the service engine soon. Any one have any ideas of how to check what is wrong, without taking it to the dealer?
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Service Emissions System
    Quote Originally Posted by anggarci
    Did you clear the code after fixing the problem...??? Disconnect the negative battery terminal to send the code to history status and see if the light goes out.
  • You may not post replies
