00 DTS Falls Flat on Face
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Northstar Engines and System Technical Discussion Discussion, 00 DTS Falls Flat on Face in Cadillac Engine Discussion; My 00 DTS has been doing this for the last few weeks that I've had it. It started out very ...
    Aurora By Olds is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DTS
    Oct 2003
    Fort Myers, FL
    33
    197
    My 00 DTS has been doing this for the last few weeks that I've had it. It started out very intermittent, but has gotten worse and worse. See YouTube vid below:
    This only happens when the throttle comes off of idle (can happen in P, D, at 10, 20, 50, 90+ MPH) and it totally falls flat on its face and stumbles until I pull my foot off. If I immediately pull my foot off and jam it back on, it's fine. Just replaced the Fuel Filter and from what I can guess the FP is ok (36-46psi) because I don't know the actual specs off hand. The pump and pressure do seem responsive enough to not be the problem.
    Once the stumble has passed, the call will pull hard and ever all the way to 130 or until I let off.
    It almost seems more like an electrical problem than a fuel problem at this point, but I don't really know where to start. Any ideas?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Re: 00 DTS Falls Flat on Face
    Pull the codes.
    Oct 2003
    Fort Myers, FL
    33
    197
    Quote Originally Posted by dkozloski View Post
    Pull the codes.
    Forgot to mention....there are none. :-(
    68
    82,058
    It does seem more electrical than fuel, but beyond that, I can't think of anything.
    STSj90 is offline Cadillac Owners Fanatic
    Automobile(s): 95 STS N* TOTALED
    Feb 2008
    244
    Is she breathing good? Is there anything in the way of her nose?Anything obstructing?(intake)
    What kind of fuel is she running on? maybe you ran into some bad gas?
    Just throwing some idea's around...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    I think what you may be seeing in that video is it hitting the rev limiter at 4k. Just a thought.
    Feb 2008
    244
    Quote Originally Posted by codewize View Post
    Doesnt sound like 4000RPM to me. Sounds like its bogging when you give it a sudden dose of throttle. Then you lift up alittle and it revs on up.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    OK, Just wondering.
    For some reason 4k never sounded like 4k to me on the N*. It was just an idea.
    Quote Originally Posted by STSj90 View Post
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Bad spot in the TPS?
    Oct 2003
    Fort Myers, FL
    33
    197
    Quote Originally Posted by chubbyranger View Post
    TPS was my first thought, but it's intermittent, and only happens when coming off of idle. Get right back on, and it goes like a raped ape.
    Its breathing fine, no leaks or obstructions. And again, its intermittent.
    Definitly not hitting the rev limiter, not even close.
    Still no codes, except for the notorious B0429....
    Maybe I will take it out tomorrow and show it whose boss for a few hours and see if anything pops up other than burnt rubber....
    68
    82,058
    You know, now that you mention it, I recall our old Guru saying that a bad TPS would act like a bad accelerator pump on a carburetor. Exactly what you are describing.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    You're right, I had that on my 89. I guess I wasn't thinking about that.
    Oct 2003
    Fort Myers, FL
    33
    197
    Guess it's possible. I'll see if I have time to check into one today. if I remember from the last time I had to buy one they're not that much.
    It does actually make sense, though. Idle (or close to it) signal to the PCM from the TPS with a WOT would do just what it's doing...
  16. #14
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,947
    Okay...I'm confused. If the redline is up in the 6K range, why would the car hit the rev limiter at 4K???
  17. #15
    68
    82,058
    Yes.
  18. Remove Advertisements
