air plenum and coolant...
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, air plenum and coolant... in Cadillac Engine Discussion; I have noticed the coolant disappearing in my 94 eldorado 4.6 litre. And have read in amongst the forum about ...
    onecad is offline Cadillac Owners Member
    Oct 2003
    98
    I have noticed the coolant disappearing in my 94 eldorado 4.6 litre. And have read in amongst the forum about the problem commonly being the headgaskets. Does anyone have any experience or insight about the possibility of it being the air plenum? I know that the gm 3.8L engine has a big problem with the air plenum walls corroding from the years of pollution, and results in an identical problem, being the coolant disappearing. Has this happened with the 4.6L to anyone's knowledge?
    Thanks
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: air plenum and coolant...
    Quote Originally Posted by onecad
    Thanks
    Cannot happen. No coolant passages in the intake at all. None. Totally dry. Done that way on purpose so that the cooling system does not have to be broken into to change the starter that is under the intake.
