99 Cadillac Seville
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 99 Cadillac Seville in Cadillac Engine Discussion; The squeaking still consists. I already changed to a new OEM tensioner and Belt. 1 week everything holds out and ...
    DaveT90 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    48
    99 Cadillac Seville
    1 week everything holds out and it starts randomly again.
    Anybody knows what to do?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Re: 99 Cadillac Seville
    DO NOT try any sort of "belt dressing" magic. Use your ears and a modified stethoscope from Walgreen (replace the chest diaphragm with vacuum tubing from a big auto parts store....) and carefully snoop around for the squeak. Understand that some pulleys and serpentine belts squeak no matter what you do.......
    If you replaced the belt and tensioner, which one: the main (front) accessory drive belt or the water pump belt which comes off the rear of the front intake cam........and is the noise like a squeak (rotating noise) or a squeal (belt dragging over a stuck pulley) ?
    Nov 2007
    48
    It is the main front accessory drive belt. The noise is like a rotation squeak. We snooped around for the squeak and it seems that it's coming from the power steering pump pulley. Should i change the whole pump or just the pulley?
