95 Seville SLS cold start problem with instant fuel pressure drop.
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, 95 Seville SLS cold start problem with instant fuel pressure drop. in Cadillac Engine Discussion; I have a 95 Seville that has cold start problems. Changed FPR, did full tune-up, checked for leaking or plugged ...
    ski4lifer is offline Cadillac Owners Member
    Automobile(s): 1995 Seville SLS
    Jan 2009
    43
    1
    Question95 Seville SLS cold start problem with instant fuel pressure drop.
    I have a 95 Seville that has cold start problems. Changed FPR, did full tune-up, checked for leaking or plugged injectors, and new TPS. When i hook up the pressure gauge to the fuel rail and turn the key on i get a 20 psi spike than it drops to zero quick. Any one have any ideas????????
    68
    81,916
    Re: 95 Seville SLS cold start problem with instant fuel pressure drop.
    Fuel pump is shot.
