Steam Engine, Now What?
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Steam Engine, Now What? in Cadillac Engine Discussion; I'm sure there have been enough of you out there that have rebuilt the NS motor, now that I'll be ...
    96CD is offline Cadillac Owners Member
    7
    I'm sure there have been enough of you out there that have rebuilt the NS motor, now that I'll be pulling the heads, should I be doing anything else while its out? Any special areas to be looked at? As you recall, I pulled it because of the thing spouting out #8 like shamoo, not to mention into the manifold then into and out of the exhaust system.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Steam Engine, Now What?
    Probably nothing else to do but the head gaskets. Timesert the head bolt holes for insurance at reassembly.
    The heads and valves are likely fine. They can go several hundred thousand with no valve job or anything. Timing drive chains and oil pump are also life time parts so they will NOT need replacement or service. Just the head gaskets......
    cadillacstars's Avatar
    cadillacstars is offline Cadillac Owners Member
    Dec 2003
    62
    aisde from time-sertting ALL of the head bolts, if you have the $$ replace every gasket that you can replace, that you cannot easily replace while the star is in the car. cheap insurance. GOOD LUCK
    CAJUN-Z is offline Cadillac Owners Member
    New Orleans, LA.
    61
    16
    What does a head gasket job normally run?....
    sts96 is offline Cadillac Owners Fanatic
    May 2004
    333
    Heavy agreement replace all gaskets on lower parts of engine even the crank sensors, all of mine were shrunken and leaking.
    no leaks now. sts96
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Yea, I would agree that fixing any obvious leaks in the lower end would be a good idea while the engine is out but if nothing is leaking then there would be little or nothing to gain by ripping the lower end apart. Just "fix" what is leaking or broken and don't make work/expense/risk for yourself.
  9. Remove Advertisements
