Erratic Throttle
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Erratic Throttle in Cadillac Engine Discussion; Well I think I seen like 2 threads concerning this but I didnt really find a solution. Under low acceleration ...
    jcdsog is offline Cadillac Owners Member
    Oct 2003
    sc
    40
    24
    Erratic Throttle
    Well I think I seen like 2 threads concerning this but I didnt really find a solution. Under low acceleration the throttle wants to rev up and down. I already have new plugs, wires, air filter, fuel filter. I did buy a shift solenoid kit but havent put it on yet (was having a slight trans jerk under low acceleration but I'm thinking its the throttle doing this too). 94 SLS N* & no codes. Thanks for the help.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Erratic Throttle
    Sounds like the idle speed control motor or the closed throttle switch inside the idle speed control motor is failing. That is the canister shaped device on the throttle body with the plunger that the throttle lever rests on. The plunger moves in and out per the PCM commands to control the idle speed. It likely needs to be replaced. Search using "idle speed control motor" or "ISC motor" in the archives and read my posts for more info.
