failed smog test again. the HC is still high @15MPH
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, failed smog test again. the HC is still high @15MPH in Cadillac Engine Discussion; I replaced spark plugs, FPR, oil, airfilter and ran about 20 minutes before the 2nd test but the results are ...
    31415926's Avatar
    31415926 is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville Sedan
    Mar 2004
    San Diego
    107
    I replaced spark plugs, FPR, oil, airfilter and ran about 20 minutes before the 2nd test but the results are same: high HC @ 15mph.
    Any ideas?
    Thanks!
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: failed smog test again. the HC is still high @15MPH
    You really need to run some fuel system tests.
    Your fuel pressure could be too high or you could have a leaking injector.
    I have seen a few of both.
    31415926's Avatar
    Mar 2004
    San Diego
    107
    Quote Originally Posted by ewill3rd View Post
    If it's a fuel pressure thing, could you tell me why it passed HC@ 25mph?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,577
    The slightly increased (engine) speed results in higher combustion chamber temperatures and thus lowers HC. Start looking at fuel pressure and injector leaks. High HC is analogous to a stuck choke in a carbureted engine. (You'll notice that one more digit in your 25 mph HC and it would also have failed. You're running rich.)
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    sub is right, the higher engine load will use up more HC, the throttle plate is open more so you have more O2 for combustion.
    At any rate, it is a place to start.
    69
    82,163
    Quote Originally Posted by submariner409 View Post
    Leaky FPR?
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    He looked for that in another thread I am pretty sure.
  10. Remove Advertisements
