00 STS Air Pumps; how many of them?
Results 1 to 13 of 13
Northstar Engines and System Technical Discussion Discussion, 00 STS Air Pumps; how many of them? in Cadillac Engine Discussion; Mine has 2 pumps, but in the FSM, they show either none, one, or two. Anybody know the why GM ...
    derone is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Cadillac STS
    Aug 2007
    NC
    133
    Mine has 2 pumps, but in the FSM, they show either none, one, or two. Anybody know the why GM had some many different setups?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,515
    Re: 00 STS Air Pumps; how many of them?
    Depends on the emissions specifications (50 state, lower 48, California) and the engine/PCM programming as well as the model of cat. If the cat lights off with a minimum of extra oxygen, depending on application, then maybe none or one pump.
    There also was a thread earlier in '08 concerning the number of A.I.R. valves/solenoids mounted on the engine (sometimes one on the rear cam cover, sometimes that plus one in front of the water pump/"upper hose" area).
    Don't confuse the emissions pump(s) with the rear level control compressor.......
    Run your RPO's......the emission compliance package is in there.
    Aug 2007
    NC
    133
    Oh, I saw both of them when I had the bib off to change the fog light bulb. There was one on each frame horn underneath the 'bib' cover in front.
  5. #4
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by derone View Post
    Yes, you saw two AIR pumps, one for each bank. The two pumps were only used in early production, 2000MY only. Two pumps were an over kill, one pump does the trick. As far as why did they use the 2 pump set up,
    IMO, they found out that one pump will push enough air into the exhaust system to light off the cat, and meet the emission standard.
  6. #5
    Aug 2007
    NC
    133
    Hey thanks for the info...mine was an early production '00, like Dec '99 if I remember correctly.
  7. #6
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Quote Originally Posted by FrankT View Post
    That explains why mine has 2... production of 8/99. Be nice if it was only 1, less to go wrong.
  8. #7
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by ejguillot View Post
    Yes, and less expense, GM did not do the homework and thought that the N* needed two AIR pumps and two control valves to light off the cat to meet emissions for 2000MY.
    From mid 2000 and to current model years, the N* has one pump and one control valve, the rear bank.
    Using only one pump and one control valve is a huge cost savings for both GM and the customer. Talk about an expensive lesson learned.
  9. #8
    68
    81,729
    I think I have only one pump, but I have two control valves.
  10. #9
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Yes Ranger that is totally possible, through emission testing and cost savings direction, GM found out that one pump and one control valve was sufficient.
  11. #10
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    03 STS
    one pump
    two valves
  12. #11
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by CadillacSTS2003 View Post
    03 STS
    one pump
    two valves
    99 STS, no pump, no valves, and rust on the left rear 1/4.
  13. #12
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    I think that one control valve didn't come into production till the 04 or 05MY Deville /DTS. Sorry if I confused anybody.
  14. #13
    Feb 2006
    55,515
    2002 mid-run STS = 1 pump, 2 valves (front and rear banks).
  15. Remove Advertisements
