98 SLS screeching noise from egen.
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 98 SLS screeching noise from egen. in Cadillac Engine Discussion; Hi all new hear Theres been a screeching noise coming from the front of the egen. It was just a ...
    MCH
    MCH is offline Cadillac Owners Member
    Automobile(s): Cadillac 96 SLS
    Nov 2008
    Livonia MI
    25
    Hi all new hear
    of the egen.
    It was just a little noise at frist
    so i take it to the shop thay replace the belt tencher? didnt help
    IM thinking water pump what do ya think Thanks Mike H
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,854
    Re: 98 SLS screeching noise from egen.
    There are TWO belts and tensioners in a 98 SLS: the water pump belt is in the "rear" (driver's side) of the engine, behind the water pump cover which is bolted to the coolant crossover. The pump is driven off the front intake cam by a small belt and tensioner. The main accessory drive is in the front (passenger side).
    If your noise is in the front (passenger side) of the engine, and replacing the main serpentine belt tensioner did not help, then there are 3 more possibilities: the idler pulley bearing, the alternator bearings, or the a/c compressor clutch bearings are going bad.
    If the noise is, in fact, coming from the water pump area, then there's a whole different procedure to remove and change that setup.
    MCH, Go up to the USER CP in the blue bar at the top of the page and enter your car, year, model in your personal data and profile. Then your login header shows that so we can see what we're trying to work on.......Welcome Aboard !!!!
    MCH
    Nov 2008
    Livonia MI
    25
    Re: 96 SLS screeching noise from egen.
    Sorry its a 96 not 98 Wifes car
    squealing New belt tensioner,and idler arm pully And alternator.
    So the water pump is on the driver side
    Could this be the noise it sounds like its cooming from the top front side
    96 SLS 104000 mi
    Thanks Mike H Livoina MI
    68
    81,894
    "Top front side" of the motor is the passengers side. I would suspect the idler or tensioner pulley bearing. Release the tension on the tensioner with a 1/2" breaker bar. Put the drive lug in the square hole on the back side and use it as a lever. Then spin each pulley by hand and see if there is any looseness, roughness or noise. If they are OK, check the A/C compressor clutch down below.
    MCH
    Nov 2008
    Livonia MI
    25
    I put a new idler pulley on a mo ago.
    I put a new tensioner pulley on 3 weeks ago.
    Last night i put a new alternator on.
    Im going to see one more time if i can here where its coming from.
    And thanks Ranger ill pull off belt and see if its the power stering
    and check the A/C compressor clutch
    THIS THING IS DRIVING ME NUTS!!!!!
    Thanks Mike H
    [NortHStaR]'s Avatar
    [NortHStaR] is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Cadillac DeVille
    Aug 2008
    Phoenix, AZ
    24
    279
    Have you checked the power steering pump??
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    I know this is going to sound stupid, because it sounds like a belt or bearing from what you describe, but check the backfire valve on the end of the intake manifold by the P/S pump. It can make a high pitched whistling that gets very annoying. Move it a bit with a screwdriver or other object to try to get it to seal. My '97 STS did this and I thought for a minute it was the alternator. Another thing that can make a whistling/high pitched sound is the EGR tubes (flex pipes) running to the throttle body and coolant crossover. If they aren't sealed properly they can emit a very annoying sound too.
    When you have it figured out let us know- we're curious!
  10. Remove Advertisements
