I need help
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, I need help in Cadillac Engine Discussion; changed the camshaft sensor and still have p041 code on cadillac 94 sts...
    Moezy is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2008
    103
    I need help
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: I need help
    Did you change both sensors? I think there are 2 but not positive for your year. Usually posted as an upper and lower sensor. Search CKP here. You'll get a lot to wade through but your answer should be here.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,529
    Re: I need help
    P041....CaMshaft Position sensor (CMP) signal fault. The single sensor in the drive belt end of the rear cam cover ? Held in by a 10mm bolt, and murder to get to ?
    If that's it, you're in the wiring harness tracing business. Might be a dirty connector.....any oil leak in the cam cover gasket goes right to that corner.
    The CranKshaft Position sensors (CKP) (2 - A & B) are down on the side of the block next to the oil filter adapter.
    OBD-II uses P0340 and P0341 for the CMP codes.
    Did you clear the codes, and if so, is the P041 Current or History ?
