strip thread in block
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, strip thread in block in Cadillac Engine Discussion; when i installed the belt tensioner, i stripped the thread in the block of N* what is the best or ...
    badboris's Avatar
    badboris is offline Cadillac Owners Member
    Automobile(s): 99 DeVille,120,000mi., 94 Lincoln Town Car
    Aug 2008
    Laval,QC.Canada Montreal area
    70
    12
    what is the best or easiest way to fix
    68
    81,883
    Re: strip thread in block
    I would think you could use a Helicoil on something like that.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,829
    A Helicoil would be OK there, but you'll need to go at it from inside the fenderwell. Move anything necessary in the engine comartment, put the front end on jackstands, and remove the wheel/tire and fenderwell liner.
    I believe your engine uses metric threads, so check first........
