'97 Northstar MAF location and codes
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, '97 Northstar MAF location and codes in Cadillac Engine Discussion; I'm getting a PCM P0101 (MAF system), PCM P1599 (engine stall), and IPC B1910 (???) 1) Where is the MAF ...
    mdogg1950 is offline Cadillac Owners Member
    Automobile(s): '90 DeVille '97 DeVille
    Feb 2005
    Iowa
    83
    1) Where is the MAF sensor on my '97 DeVille?
    2) Any thoughts on how to check? (Loose sensor, vacuum leak, or ?)
    3) What does IPC B1910 mean?
    Thanks in advance,folks.
    Matt
    68
    81,891
    Re: '97 Northstar MAF location and codes
    The MAF sensor is the Black plastic think bolted to the intake side of the TB and the intake duct is strapped to it.
    B1910 - Generator L-Terminal Open Circuit
