93 STS cooling system/h-gasket problem
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 93 STS cooling system/h-gasket problem in Cadillac Engine Discussion; Hi, I am having some unfortunate issues with my 1993 STS. It started with me getting the "check coolant level" ...
    friesianfever is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    4
    Hi, I am having some unfortunate issues with my 1993 STS. It started with me getting the "check coolant level" light coming on all the time. It slowly got worse and worse until I had to add water to the coolant reservoir every time I drove it to work etc. Then the car would also not always turn on when I turned the key, one day it wouldn't start at all. I had to have it towed and replace the starter, the mechanic said the starter housing was cracked so I had that fixed for nearly 600$ (not sure if those two things are connected or not?). The same mechanic had a look at my cooling system and informed me that there was a crack in the thermostat housing, and water pump housing. I got him to fix that problem, but when I went to pick the car up there is an obvious increase in white smoke coming out of the tail pipe. He told me to get rid of the car as it could be a head gasket, but I am not so sure. Before I took it to him it didn't have much smoke coming out at all. His explanation was that now that the leaks in the cooling system have been fixed, that there is more pressure in the system making the smoke come out??? It seems like everytime I take it to get some work done on it something else goes wrong right after, do you think he sabotaged my car or is he being honest?
    I got some new codes, I have looked them up but don't really know what they mean if someone has some advice I would really appreciate it.
    P035 (history), P052 (history), , P109 (history)
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: 93 STS cooling system/h-gasket problem
    He's probably right about the HG's.
    He is right that fixing the outer leaks is going to increase pressure on the inside leak.
    Apr 2008
    4
    Thanks for your opinion. Do you think that means the head gasket is done for, or is this something I can fix before it gets worse? Any other reasons why there might be white smoke? I thought maybe because I don't have a working cateylic converter? Thanks again.
    Any other opinions out there?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,170
    Take the time this weekend to search this forum and up in Seville for threads concerning head gaskets and overheating. You will find many similar answers to your question.
    69
    82,393
    I doubt that he sabotaged the car. If the white "smoke" is steam and smells like coolant, then the head gaskets are probably done for.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    H/g..
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Yep - hg
  10. Remove Advertisements
