95 Eldorado stalling
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 95 Eldorado stalling in Cadillac Engine Discussion; I have a 95 Eldorado with the 270HP Northstar engine with just under 100,000 miles on it and I have ...
    Chantry is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    47
    I have a 95 Eldorado with the 270HP Northstar engine with just under 100,000 miles on it and I have been having problems with the car stalling for about a month now. My mechanic can not seem to find the problem as the computer is not listing any current codes. Below are the following codes that are in the history:
    I022 Panel Dimming Switch Pot Circuit (History)
    T072 Serial Data Link Fault (History)
    S036 Electronic Level Control Compressor Short to Ground/Open (History)
    S044 Lift or Dive Signal Fault (History)
    S066 Left Rear Position Sensor Overcurrent (History)
    P061 (E061) Cruise - Vent Solenoid Problem (History)
    I don't believe the above codes are relevant to the problem
    P032 (E032) Open MAP Sensor Signal (History)
    P071 (E071) Intermittent MAP Signal (History)
    P095 (E095) Engine Stall Detected (History)
    No APC Codes
    No SIR Codes
    My mechanic has replaced the computer itself (ECM Module) and both crank position sensors were changed today and the car is still stalling out when it warms up. When the problem first began to manifest itself there would be small spikes in the RPM's, about 150-300 rpm. The car seems to be running slightly rougher then normal (a tune up was done within 30,000 miles) and the problem becomes much more severe when turning the car on and off while running errands.
    The car does NOT seem to stall under the following conditions: in Park or Neutral, with the RPM's around or above 2000 rpm or in 3rd.
    Thanks for any help you may be able to provide.
    (On edit: I tried using search, but did not see anything with the exact symptoms that continued to occur after replacing the CKP sensors)
    68
    81,891
    Re: 95 Eldorado stalling
    Just shooting from the hip here, but you might look into that MAP sensor.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    On a side note, I really hate how mechanics always avoid real investigation by just throwing parts at the problem and replacing the ECM whenever they can't figure out an electrical problem.
    Oct 2008
    47
    Ranger: It seems it was the MAP sensor after all. Thanks!!
    PlayDrv4Me: He replaced the ECM becuase he got a fault on it when he ran the codes the first time he had it and the CKP sensors were replaced at my insistence.
  7. Remove Advertisements
