Please help with eratic idle!!!!!!!!!!
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Please help with eratic idle!!!!!!!!!! in Cadillac Engine Discussion; Hi guys, I have a 99 sts that has an eratic idle or hunting idle(up and down)after its warmed up ...
    VIPERRACING is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    58
    Hi guys, I have a 99 sts that has an eratic idle or hunting idle(up and down)after its warmed up and sitting in traffic. It doesnt do it when I turn on the a/c. Any help would be appreciated. Thanks, Tony.
    68
    81,916
    Re: Please help with eratic idle!!!!!!!!!!
    Sounds like a vacuum leak, but start with a good TB cleaning if you haven't done it recently.
    Mar 2008
    58
    It only does it when im stuck in traffic. I turned on the a/c to see what would happen and it kept a steady rpm. I was thinking that it was the egr. Could it be the egr valve?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    The fix is probably to: Do a good throttlebody cleaning. Do a good EGR valve cleaning. Pull the engine cover and do a thorough search for vacuum leaks.
    If turning on the A/C temporarily cures the hunting, then the problem may be an erratic ISC system: the A/C ON command also increases idle speed slightly, so that function may either move the throttle butterfly or increase idle air just enough to "cure" the problem.
  7. Remove Advertisements
