Dyno Run
Results 1 to 15 of 15
Northstar Engines and System Technical Discussion Discussion, Dyno Run in Cadillac Engine Discussion; Well technically its a Dynolicious Run... I downloaded the new app to try on Niks ipod touch that i bought ...
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Dyno Run
    I downloaded the new app to try on Niks ipod touch that i bought her after raving reviews about how accurate it is.
    Well on the way to school i was able to get 2 good runs in and heres how the 03 STS with Corsa & K&N Panel Filter stacked up
    Weather Clear Night
    Outside Temp 80 Degs
    Info on Car that is inputted:
    Weight 4200 lbs with driver
    Drivetrain Loss 25%
    These are the results according to the Ipod for the runs
    Results of an Average of the 2 Runs
    0-10 .92 secs
    0-20 1.86 secs
    0-30 2.94 secs
    0-40 3.97 secs
    0-50 5.21 secs
    0-60 6.76 secs
    0-70 7.79 secs
    0-80 9.40 secs
    Elapsed Time:
    60' 2.65 secs @ 25.8 MPH
    330' 6.66 sec @ 57.8 MPH
    1/8 9.62 sec @ 79.2 MPH
    1000' 12.24 sec @ 93.1 MPH
    1/4 14.59 sec @ 88.6 MPH
    Miscellaneous:
    Max Speed 81.5 MPH
    Max Acceleration .87 G's
    Peak HP 243 HP
    NHRATA01 is offline Cadillac Owners Fanatic
    Automobile(s): '12 Regal GS, '01 Trans Am
    Jan 2008
    New York
    248
    Re: Dyno Run
    I'd heard about that program, never tried it.
    The drag times look somewhat inaccurate. A 2.65 60' is horrific, I bet taking it easy you should easily get a 2.3, and with a decent hook on a good surface and skilled throttle modulation, a 2.2 or 2.1 shouldn't be out of the question. And IMHO the MPH on the 1/4 time is probably about 4-5mph too low for that ET on a FWD car...especially if the 60' was that poor.
    Oct 2005
    15,987
    Re: Dyno Run
    for what it is a 14 dollar app id say its a decent indicator to say the least
    again though it was the average of two runs one of which i had a hugely hard time hooking up (sucks on gravel roads) so that likely skewed them a bit
    i suppose i should post individual results for each run maybe?
    RodneyPierce is offline Cadillac Owners Fanatic
    Automobile(s): 98 STS
    Aug 2008
    32
    146
    Re: Dyno Run
    ive got to disagree on one small subject. the worse the short time usually means more mph. If you have a shitty short time then you have more time to build MPH.
    Jan 2008
    New York
    248
    Re: Dyno Run
    Quote Originally Posted by RodneyPierce View Post
    That was what I was implying in my post. The MPH on the trap is too low, even with a decent 60'. Would be even higher on a bad 60'.
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    35
    963
    Re: Dyno Run
    Thread title misleading, Dyno run is not equal to Accelorometer run, but it's cool you can use your Ipod Touch as a G-Tach...
    ejguillot's Avatar
    ejguillot is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 Seville STS
    Jul 2006
    Tampa FL
    42
    985
    Re: Dyno Run
    Quote Originally Posted by Raze View Post
    Apparently it's better than a G-Tech. The guys at Garage419 think so, after their testing:
    [YOUTUBE]0-DFbJQbeSY[/YOUTUBE]
    Plus in the video they show that the Dynolicious software's HP estimate was within 5HP of the dyno run they did.
    Raze's Avatar
    May 2004
    Atlanta, GA
    35
    963
    Re: Dyno Run
    accelerometer's readings are only as 'accurate' as the inputs you provide, if Jay weighed his car with himself and fluids and whatever other material in there, and knew for sure what the drive line loss is, assuming the HP rating is accurate, most dyno runs of N*s have shown a trans loss anywhere from 25% to as much as 30% it just depends case to case. I'm not doubting, just saying there's a lot of potential inaccuracies and claiming this is as a 'dyno' run is misleading...
    Oct 2005
    15,987
    Re: Dyno Run
    factory weight is 3996 LBS
    i figured with me half tank tools etc im pushing 4350-4400 lbs
    i was told by the makers when i contacted them if i leave the dt % clear ill get wheel HP
    weight and % loss are the only inputs
    today was a really shyty run and i got a 7.08 0-60 and a 15.02 1/4.
    BlackCaddy87 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Cadillac Concours
    Apr 2007
    Russellville, AR
    30
    186
    Re: Dyno Run
    why would your 1/4 be a lower trap speed compared to your 1000ft?
    msta293412 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 cadillac sts
    Jan 2006
    south florida
    44
    285
    Re: Dyno Run
    yea, I call BS.
    Apr 2007
    Russellville, AR
    30
    186
    Re: Dyno Run
    maybe he just let off too early
    Oct 2005
    15,987
    Re: Dyno Run
    because its an average...
    try reading the whole thing before raising the BS flag...
  16. #14
    Apr 2007
    Russellville, AR
    30
    186
    Re: Dyno Run
    does it tell you when you've completed the 1/4 mile?
  17. #15
    Oct 2005
    15,987
    Re: Dyno Run
    emits a beep with to be honest is rather hard to hear over the Corsa at WOT
  18. Remove Advertisements
