pulled code pcm0443
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, pulled code pcm0443 in Cadillac Engine Discussion; P0443 - EVAP Purge Solenoid Valve 1 Control Circuit I orderd a EVAP Purge Solenoid and replaced reset light and ...
    Mrjb9475 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS
    Oct 2006
    197
    pulled code pcm0443
    P0443 - EVAP Purge Solenoid Valve 1 Control Circuit I orderd a EVAP Purge Solenoid and replaced reset light and came back on does anyone know what else can cause this? car is running fine thanks for the help
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Re: pulled code pcm0443
    Check the connector and circuit ground for the solenoid. Because this is part of the entire fuel tank pressure/vacuum and emissions vapor purge system, you should check the integrity of the gas cap, filler neck, and vapor hosing to the evap canister.
    According to the '02 Seville factory manual if the system is repaired it will clear the light after 3 successful start-run cycles and the code will go to History, and that will clear after 40 successful cycles. The light can also be turned off with a GM Tech-II scan tool. There's also something in that diagnostic concerning an internal driver which must receive proper voltages. Sounds like power or ground problems.
    Frans96SS is offline Cadillac Owners Member
    Mar 2004
    27
    QuestionRe: pulled code pcm0443
    Where is this valve located? My car is having the same problem and is also idling high.
    68
    81,928
    Hard to say without knowing your model and year. Probably on the rear cam cover. Please update your profile.
  7. Remove Advertisements
