Oil pressure after HG repair
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Oil pressure after HG repair in Cadillac Engine Discussion; First i want to thank everyone for all the information that this forums offers. It has been really helpful while ...
    AKBanzai is offline Cadillac Owners Member
    Automobile(s): 98 STS
    Jul 2007
    Anchorage,AK
    27
    16
    ExclamationOil pressure after HG repair
    First i want to thank everyone for all the information that this forums offers. It has been really helpful while doing my HG repair on my 98 sts and i don't think i would have attempted the repair with out this information. Now on to my problem.
    I am almost done with my HG repair except for getting oil pressure. The engine sounds great except for the ticking in the heads because no oil pressre. I have tightened the harmonic balancer bolt, tried to prime the pump with adding 16 quarts of oil, pushed oil throught the oil filter adapter hole as it states in the manual, replaced the sensor installed a gauage, and for the life of me cant get pressure. I am about to pull the harmonic balancer and the front cover and check out the oil pump. i was just wondering if you guys have any suggestions.
    Thank you!!!!
    68
    81,897
    Re: Oil pressure after HG repair
    You've already done everything I would have thought of suggesting. tightened the harmonic balancer to the proper specs?
    Jul 2007
    Anchorage,AK
    27
    16
    Yeah i did, and them some. One question when i do put the harmonic balancer on it should be flush with the crankshaft just like the water pump pulley and the power steering pulley.
    68
    81,897
    Someone else will have to answer that one. I've never had to do one.............. thankfully.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Actually, the same thing happened to me upon starting after the HG job. I never posted it on my thread but it was noisy so I checked everything but it was all fine. I got so frustrated I took it for a ride and floored it a few times, then she quieted right down to whisper quiet as it is to this day. Can't explain it exactly, but I would suggest you drive it a little and see if it gets better.
    The balancer bolt washer should position the balancer to the proper position - it needs to be all the way in, since the oil pump drive is squeezed between the pulley hub face and the crankshaft flange
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Newer engines restrict oil to the heads. If the lifters bled down it will take a while to pump them up.
    Do you have oil pressure? How long has it run? It took a scary long time to pump on the second one I did. Started it multiple times and let it run a short while each time. Eventually they quieted down. The real running time was probably 2-3 minutes.
    Jul 2007
    Anchorage,AK
    27
    16
    I dont have any oil pressure at all.
    Sep 2003
    Arizona
    3,531
    Then that's not good.
    The torque was really high for the balancer bolt. I think 250 ft/lbs.
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by zonie77 View Post
    I think the spec is actually 37 ft lbs plus 120 degrees. I didn't find that to be that tight, so when I did my HG, I loosened it and retightened, just to be sure, but it really didn't feel like more than maybe 100 ft lbs
    Jul 2007
    Anchorage,AK
    27
    16
    Well im going to take the Harmonic Balancer off and try again. Hopefully thats all its is.
    Jul 2007
    Anchorage,AK
    27
    16
    Is the end of the crankshaft suppose to be flush with the harmonic balancer?
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    When I put mine back on it stuck out just a little from the end of the crank - I think that is the way it is supposed to be, or at least that is all the farther I could get it on with my Harmonic Balancer Tool. If I remember correctly, it was not flush when I removed it.... but I could be mistaken.
    Jul 2007
    Anchorage,AK
    27
    16
    Thank you guys for all your help. It was the harmonic balancer. I took the bolt off and it look like it was on far enough but just in case it wasn't i took a wood block and hammer to it and put back together. And... presto there was oil pressure. Just have to figure out a few codes and why my windshield wipers wont come on. P0111,p0113,p1111,and c1760. Once again thank you guys.
  16. #14
    Dec 2007
    Ledyard, CT
    57
    299
    AKB - after you hit it with the hammer was it flush? or was it sticking out just a little?
  17. #15
    Jul 2007
    Anchorage,AK
    27
    16
    sticking out a little. like there was a lip on the balancer
  18. Remove Advertisements
