Loctite Red Gel REMOVAL!!!!!
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Loctite Red Gel REMOVAL!!!!! in Cadillac Engine Discussion; This is going to sound crazy, but I was installing the inserts in the block I had just prepped using ...
    mikelawson is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2008
    123
    This is going to sound crazy, but I was installing the inserts in the block I had just prepped using the new and improved loctite red gel. As I have done in the past (using red liquid) I screwed the inserts even with the block and was going to go back and use the insert tool to drive them the rest of the way down, but to my surprise this stuff had already setup. I was able to drive down most of them, but I have two that I cannot get out. They are even with the block and I have nothing to grab on to. I was thinking of a reverse thread 11X1.5 bolt and heating the bolt as to not warp the block. Any other ideas and where am I going to find a reverse thread bolt???
    Thanks, Mike.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Loctite Red Gel REMOVAL!!!!!
    I haven't used that yet. I'll just say that if you don't get an answer call Loctite and see what they say.
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    What inserts are you using? Couldn't you just heat the insert with a small butane torch, one of the small pencil types, and just continue to drive the insert home?
    69
    82,287
    I'd think heat will do the trick, but maybe this will help.
    http://www.type2.com/library/chemicals/loctite.htm
    Villanous's Avatar
    Villanous is offline Cadillac Owners Member
    Automobile(s): 96 Eldorado base model 4.6Northstar
    Aug 2008
    Boston
    53
    When removing bolts or fasteners that have had loctite used on them many times heat will do the job.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by mikelawson View Post
    Thanks, Mike.
    I do then one at a time.
    Next
    I clean the holes out in the block with Acrysolve or adhesive remover.
    I do this when a block is good and doesn't need TimeSerts. You have to get that crap out of the holes before installing the new bolts.
    Villanous's Avatar
    Aug 2008
    Boston
    53
    When installing bolting it is good practice to chase the holes with a bolt to make sure they will thread in with no issues.
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by Villanous View Post
    I use adhesive remover in the holes when I chase/clean them out
    Villanous's Avatar
    Aug 2008
    Boston
    53
    I agree with that , use a solvent or a solution to soften any crap in the threads.
    I would suggest using a bolt to chase the holes since the material is aluminum chances are the bolt wont cut new threads as opposed to a tap. Not that it happens all the time but taps can be prolematic if they cut new threads upon threads.
    Granted this really only applies to applications where you are reusing bolting that has a specific stretch and the threads in the hole share the same stretch. Sometimes I deal with an engineer that wont let us tap holes for that reason.
  12. Remove Advertisements
