seriously clogged purge line! need help!
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, seriously clogged purge line! need help! in Cadillac Engine Discussion; My uncle 98 deville has an overheating issues. I offered him help, and I started looking for overheating threads in ...
    SoWorriedDriver is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    38
    8
    My uncle 98 deville has an overheating issues. I offered him help, and I started looking for overheating threads in this forum. it was so helpful. a lot of good info.
    So, I started first by checking the purge line to make sure it is ok, but it wasn't. There was no flow at all.
    I tried to blew it with air pressure. but it didn't help.
    the long pipe under the beauty cover is ok and the rubber tube at the ends are ok too. I think it has a plug inside the fitting of the pumphousing or somewhere deeper.
    I tried a finishing nails, clothes hanger, thick wires but it didn't help too, because of that fitting has two 90-degree curves.
    my questions are:
    Could it be ok but there is something else responsible for water/air not coming out of the purge line?
    Or is it certainly clogged?
    If it deeply clogged, do I have to resemble any thing to clean? or could I do it with some special tool, and save myself removing things?
    please help!!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Re: seriously clogged purge line! need help!
    A pretty good tool is the string from a weed whacker. In the old days, a piece of speedometer cable in a quarter inch electric drill would do it.
    Don't mess with Binky Bear!
    Aug 2008
    38
    8
    dkozloski,
    Thank you so much for the help.
    I'm going to try the electric drill. but I am not sure I have a speedometer cable.
    I will try with other cables. and be back.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    for the mean time just remove the line from the overflow
    Aug 2008
    38
    8
    Quote Originally Posted by CadillacSTS2003 View Post
    Yeah, I did that.
    but the 90-degrees curves made it impossible to go deeper. I think I have to resemble the throttle body right? do I need to buy TB gaskets? what should I be aware of before I start?
    69
    82,262
    I can't imagine that you'd have to disassemble anything to clear it. An .080 diameter weed wacker line should do the job.
    Aug 2008
    38
    8
    Yeah, I think I went too far on that.
    The thing is that the fitting is so rusty inside.
    a flexible electric wire went ~3" inside the fitting, and still no water/air coming out.
    I would try a weed wacker line, but I don't have it and don't know where to buy it. I'll look for it.
    I'm not going to disassemble any thing now. I'll just try everything I could before I do that.
    Thank you Ranger.
    Thank you CadillacSTS2003
    Thank you gentlemen.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    It sounds like he's had problems for awhile and has been adding water, even worse would be adding some head gasket fix in a can.
    If he added the HG fix you may have to disassemble to clean it properly. You probably should drain and refill the cooling system with the proper mix.
  11. Remove Advertisements
