N* cylinder numbers
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, N* cylinder numbers in Cadillac Engine Discussion; I have a 2000 ETC with a head gasket starting to leak, which I think has fouled out the plug. ...
    shawn00ETC is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    14
    N* cylinder numbers
    I have a 2000 ETC with a head gasket starting to leak, which I think has fouled out the plug. I got a code for a misfire on cylinder 1. I searched but could not find out how the cylinders are numbered on the N*. So, where is cyl #1? Thanks in advance.
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Re: N* cylinder numbers
    If memory service me right..the cylinders are 1357/2468 but I can remember anymore. Been a while since I actually looked. I believe cylinder 1 in the first cylinder on the right bank (back left side of bay, looking at front of vehicle). Someone who remembers, or has messed witht he wires recently might was to chime in.
    68
    82,070
    I believe Danbuc is correct. 2-4-6-8 on the right (rear) bank. 2 being on the passengers side and 8 on the drivers side. Left (front) bank would be 1-3-5-7.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Forget the coil pack....earlier system, cylinder ID is the same............click and scroll in......
    68
    82,070
    Oops. Thanks for the correction Sub.
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    On my 99 the other giveaway is the big 2-4-6-8 stamped in the camshaft cover next to each cylinder on the front bank. They may have stopped that in 2000 with the CoP cartridge that covers those spots.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by shawn00ETC View Post
    Right Rear corner
    Make sure you have spark!
    This is the #1 cause of misfires on 2000 + Northstar's.
    As a matter of fact GM redesigned that also for 04. You Can or Can't get individual coils. In 2004 they went to 8 individual coils that come apart, but I don't no if GM sells them individually
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    The Northstar is unique in the GM engine family.
    Typically the forward bank is where #1 is with GM. 'Left side, drivers side.' Not Northstar.
    On the Northstar bank #1 is the rear forward bank. Passenger side is #1.
    Logan Diagnostic LLC
    www.ledfix.com
    www.airbagcrash.com
    www.logandieselusa.com
  11. Remove Advertisements
