Mechanics - Chicago area - Help
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Mechanics - Chicago area - Help in Cadillac Engine Discussion; Does anyone found a good, decent mechanic that tells you exact if you need to change only what you really ...
    egheorghe is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac Deville '98
    Jun 2008
    Chicago
    151
    Does anyone found a good, decent mechanic that tells you exact if you need to change only what you really need to change?
    Please help, I need to find a mechanic that i can trust to leave the car in the shop until he fixes it. NW Chicago would be perfect, but I can drive a bit further for a good mechanic.
    Thank you!
    digitalcaddie is offline Cadillac Owners Fanatic
    Automobile(s): '02 Escalade
    May 2005
    200
    Re: Mechanics - Chicago area - Help
    Dugan's Auto in Sugar Grove is good. The owner, Mike, basically works out of his barn, but the guy is honest and truthful. I've taken misc things on two Cadillacs to him. He doesn't have all the computer stuff that the dealerships have, but he still knows his stuff.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    whats wrong with the car....
    Jun 2008
    Chicago
    151
    Thanks for info. i'll try it soon.
    The idle is kind of shaky at cold starts. I changed the plugs, cleaned the EGR valve and TB, checked the FPR. I'll check the injectors and the coil. After that i don't have any idea what my next target will be.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Head gasket, maybe
    Jun 2008
    Chicago
    151
    isn't that supposed to cause the coolant level to drop. i've been checking the level for the past 3000 miles - No changes. There is a slight irregular idle after it warms up too but not as bad as when cold. I don't get any codes beside TCC stuck off/on. i remember when i changed the plugs, two of them had a gas smell. I can check them again and also check for a vacuum leak.
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Yeah - if coolant is leaking into the cylinders and causing rough running when first started cold, your coolant level would have to be going down
    Jun 2008
    Chicago
    151
    Actually there is a slight irregular idle even after warming up the car, but not as bad as when cold.
    I noticed a strange noise, like a vacuum leak on the left side of the engine (highlighted in yellow) Any suggestion where that leak could be? When the engine is hot I guess the gap becomes smaller and the idle gets better but still, every 15-30 sec I can hear that noise.
    Thank you
    96Fleetwood's Avatar
    96Fleetwood is offline Auto Enthusiast
    Automobile(s): 1992 Eldorado Touring
    Jul 2005
    Naples, FL
    37
    3,688
    Call Rob at Tepco. He is a friend of mine and is a great mechanic and enthusiast.
    3810 W. Belmont Ave
    Chicago, Illinois 60618
    773-539-1998
    Tell him Elias with the black Fleetwood sent you
    2015 Audi Q7 3.0T S-line - my DD
    2013 BMW Alpina B7 - wife's DD
    2002 Pontiac Trans AM WS6 Convertible Collectors Edition
    1992 Cadillac Eldorado Touring Coupe
    Jun 2008
    Chicago
    151
    Thank you Elias
    Jun 2008
    Chicago
    151
    I messed to attached the picture.
    68
    81,922
    That is where the manifold over pressure relief valve is. It's tucked way back in the manifold, behind the P/S pump, but you can see and feel it if you try. It's just a big spring loaded flap. Probably just a bad or dirty seal.
    Jun 2008
    Chicago
    151
    How can I get that fixed? Do I have to take out the manifold to access it and clean?
    It makes the same noise when I accelerate and couple of second after. At idle I can hear it once every 30 sec or so, when the idle is not steady.
    Could that be the cause of my idle issue?
  16. #14
    68
    81,922
    Most likely you will have to remove the manifold, but you could try getting you fingers in there. it's behind the P/S pump and pretty tight as I recall.
  17. Remove Advertisements
