N* dissassembled engine found
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, N* dissassembled engine found in Cadillac Engine Discussion; I found on local ads a N* in pieces (96 "Y") for dirt cheap, if anyone is interested, PM me. ...
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    I found on local ads a N* in pieces (96 "Y") for dirt cheap, if anyone is interested, PM me. I know nothing of the source.... Just found it, might be worth something to someone....
    Details are:
    " Northstar 4.6L Engine Block from 1996 Cadillac Deville 'Y' engine. Block stamped with part number 12554367-1
    Cylinder sleeve walls in very good condition; possibly just need to be honed for engine rebuild. Engine block includes engine main caps girdle and oil splash shield...sorry no oil pan or heads.
    No spun bearings on main bearings and no damage to engine block or main cap girdle. You may take all or some of the additional parts pictured with purchase of engine block. Engine was run low on oil causing front connecting rod bearings to seize up...this is why I am selling as block with extra parts since crankshaft and two connecting rods would require replacement or machining.
    Crankshaft may be able to be turned down if oversized bearings are used."
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    Re: N* dissassembled engine found
    how much? I need a coffee table. Throw me a PM with info.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Ooooh what a sexy idea
    Im sure my wife would love that
    Quote Originally Posted by Crown Vic Owner View Post
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,237
    Long, long ago, in a galaxy far, far away, I cut a piston across the wrist pin holes, polished it and gave it to an ex-GF for an ashtray. Ran across her some time back and she asked if I remembered my piston. I chuckled and said "Yes". She smiled and replied that she still had it. 'Twas a most fortuitous reunion.......
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    I rebuilt a Toy 2.2L because my sister in law ran it out of oil (remember, she bought a toy because they are so reliable she didn't even pop the hood for a year.... 35K miles later....), we technically the oil was still there.... Just stuck to the cyl walls.....
    I gave her the #1 piston that was cracked from the heat for an ashtray.... I don't think she kept it long, but she did learn to check the oil and even change it now and again....
    That N* is on Craigslist for $70.... Cheap end table....
    68
    82,070
    Quote Originally Posted by submariner409 View Post
    Why you ole .
  9. Remove Advertisements
