Northstar fuel rail redesign
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Northstar fuel rail redesign in Cadillac Engine Discussion; The fuel rail on my 99 STS began leaking fuel a while ago. The construction of the fuel rail is ...
    tman2093's Avatar
    tman2093 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 White Diamond STS with Sirius, 2001 Silverado
    Jun 2006
    Chapel Hill, NC
    440
    The fuel rail on my 99 STS began leaking fuel a while ago. The construction of the fuel rail is to blame. The rail consists of 8 plastic pods that hold the injectors with molded plastic tubes between these pods. Mine began leaking out of the hose between 2 injectors.
    I went to the dealer to get a new one, muttering about the cost of it, only to be pleasantly surprisedat the new rail. GM has issued a redesign. The new rail has a few key upgrades. It's a full metal construction. The fuel pressure regulator, formerly located on the rear bank of cylinders, is relocated to the front bank, the fuel return line does not go under the throttle body like the old one does, and the fuel line pressure release is moved to the rear cylinder bank. The new rail does not require a dedicated ground as the old one did, it groundes through the way it mounts to the intake manifold, by mounting under the engine cover studs.
    Just thought id pass along the information to you all.
    69
    82,180
    Re: Northstar fuel rail redesign
    It is probably the same stainless steel rail that was used on the '95 - '97 recalls.
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    56,606
    Yes, that entire series had a TSB and GM initiated fuel rail recall. I think the 2000 redesign went to metal rails OEM. Somewhrer in here or Seville I recall seeing a 99 with plastic rail, maybe a year or so back. The guy was having fits splicing in pieces of fuel hose.
