1994 Deville con
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 1994 Deville con in Cadillac Engine Discussion; I have a 1994 deville concourse - It runs rough. I replaced the MAP sensor and replaced the spark plugs. ...
    Dave34698 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    1
    1994 Deville con
    The converter has been beat out by previous owner.
    When I pull the 4&6 plug wire it does change how it runs.
    No codes
    So how do I check if this is a coil pack & Spark, or fuel injector?
    Thanks
    David
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: 1994 Deville con
    if 4 and 6 are both on the same coil pack that might be a hint. does it run better or worse with those plugs pulled?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Make sure your plug wires are connected like this: (click and scroll in). (Northstar only....)
