where does this thing go (headgasket job)
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, where does this thing go (headgasket job) in Cadillac Engine Discussion; Hey guys, my head gasket project is coming along nicely and I'm in the process of putting everything back together. ...
    lapwizrus is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    22
    Hey guys, my head gasket project is coming along nicely and I'm in the process of putting everything back together. The heads are on, along with the crossover and the exhaust manifolds. Timing is set as well.
    Here is my questions, for the life of me I do not remember where this thing goes:
    Here are some engine shots
    So any ideas?
    tman2093's Avatar
    tman2093 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 White Diamond STS with Sirius, 2001 Silverado
    Jun 2006
    Chapel Hill, NC
    440
    Re: where does this thing go (headgasket job)
    I can't believe noone has responded yet. Courtesy bump, as well as it looks like an exhaust shield, look around at the path the exhaust takes, specifically the crossover pipe.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    I am thinking... looks like maybe it goes close to the EGR valve somewhere?
    Hmmm... what year is this?
    AJ might know off the top of his head if you can find him.
    68
    81,917
    I was going to suggest the EGR heat shield, but wasn't sure enough.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    I just spent some time looking and going through the 02 FSM. No joy.
    It looks like some sort of shield or safety preventer to keep a pipe or hose from popping off a fitting.
    It's awfully clean to have come from outside the engine unless you scrubbed it........
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    It is an exhaust heat shield that protects the vehicle speed sensor from the heat off the right/rear exhaust manifold. I bolts to the same bolts as the right/front brace between the transaxle and the engine. I can see in your 2nd engine pic where it goes. Let me know if you need some more help
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    I am pretty sure he's right. I think I do remember it going down there.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by tateos View Post
    Yes it goes over the Trans output speed sensor.
    That would be on a 98 Seville correct?
    Nov 2007
    22
    You guys rock.
    Take a look at this.
    Couple more weeks and she will be back on the road. Thank-you all.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Wow that was good. I'm impressed.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    Back when I managed an aircraft engine overhaul shop, whenever we had an installation come in that we hadn't seen before we took many detailed pictures for just this very reason. It saved our bacon more than once.
    Don't mess with Binky Bear!
  14. Remove Advertisements
