no start lots of codes network ?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, no start lots of codes network ? in Cadillac Engine Discussion; well as it says my car wont start it turns over but doesent want to start. i have checkd the ...
    smooththg6969's Avatar
    smooththg6969 is offline Cadillac Owners Fanatic
    Automobile(s): 99 Seville SLS( parts) ,98 sts
    Feb 2003
    121
    want to start. i have checkd the battery grounds harness and every thing i could think of. I do have a lot of codes but as far as P codes go i get no pcm data on the DIC and have a lot of U1255 codes current.
    i have these current code stored
    DIM U1255
    IPC U1255
    IPM
    VTD
    SDM
    RIM
    RFA
    and it says no IRC data, no pcm data, no rss data
    thanks in advance guys
    68
    81,723
    Re: no start lots of codes network ?
    See if you have any fuel pressure at the fuel rail. Do you hear the fuel pump run for 2-3 seconds at key on (put your ear to the open filler pipe)?
    Feb 2003
    121
    well i got it running Ranger. im a pretty good mechanic this just had me stumped for a day or so. then i remembered something i was tought in automotive electrical class when a lot of weird things are happening with more than one system its most likely a bad ground. in my case theres a ground connector in the back left side of the block by the coolent temp sensor that some how got disconected. which caused my problem. thanks a lot Ranger.
  5. #4
    68
    81,723
    Glad you got it fixed. That would have taken me forever to discover.
  6. Remove Advertisements
