Results 1 to 2 of 2
Thread: 94 Eldo ETC
    Mar 2004
    Michigan
    51
    3
    94 Eldo ETC
    I have a 94 Eldo ETC, something keeps blowing my cooling fan fuse. have checked the fans with direct power, they are functioning properly. Could it be the relay or the temp. control switch?????
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: 94 Eldo ETC
    A relay should not blow a fuse; its nothing more than an electrically controlled switch. Sounds like you may have a short in the wiring harness somewhere or your fans are pullling excessively high current. Does the fuse blow if the fans are disconnected? That would indicate a wiring short. If the fuse waits to blow until the fans start that would indicate an over-current situation caused by one or both fans.
  • You may not post replies
