Professional Coolant Flush
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Professional Coolant Flush in Cadillac Engine Discussion; I have a 99 SLS with 76K miles; cooling system has been well maintained and car has never overheated(I have ...
    rhw1 is offline Cadillac Owners Member
    Automobile(s): 99 SLS
    Dec 2007
    Atlanta
    74
    I have a 99 SLS with 76K miles; cooling system has been well maintained and car has never overheated(I have owned the car since almost new). I see that past posts recomment drain and fill of coolant. Does a professional coolant flush(such as with MG machine) offer any added benefit that may help me avoid the prevalent HG problem?
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    54
    3,516
    Re: Professional Coolant Flush
    One school of thought here is that you are inheriting the last guy's garbage when you use a flush machine. When you do a drain and fill you can only get ~1/2 the coolant out of the car so you need to do it periodically to eventually get it all. If you keep the coolant maintained properly through either method it should afford you the same level of protection. If you use a flush machine though it must spit Dexcool into your car unless you want to convert to green coolant which is not recommended. And don't worry, on 99s the HGs don't blow until 100,000 miles so you can do the major service at the same time Only $4K later I still need to change the plug wires .
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,930
    If the system has been maintained then save the cash and do a drain and refill yourself. I don't think I'd do a flush unless something got into the system.
    If you're worried about corrosion protection then do a drain and refill, then do it again in 6 months or so. But I think you'll be plenty safe after the first one.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    70
    962
    Quote Originally Posted by rhw1 View Post
    You know the history of the vehicle. No added benefit with a machine and, as been said above, might not even be a good idea. Continue with what you've been doing - best thing for it. K_C
  7. Remove Advertisements
