Oil Adapter housing Problems :(
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Oil Adapter housing Problems :( in Cadillac Engine Discussion; I need urgent help, i took out my oil adapter housing, and when i placed it back on my 2002 ...
    thump_21 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Deville (Base)
    Aug 2007
    28
    30
    I need urgent help, i took out my oil adapter housing, and when i placed it back on my 2002 deville started splurting oil, the two bolts had 3 gaskets/wahers when i took em off and put them back on, is there a another gasket i may have missed or did i miss seat the adapter on wrong??
    Sep 2003
    Metro ATL
    4,854
    Re: Oil Adapter housing Problems :(
    I'll take a guess you are talking about the oil filter adapter.
    There should be two bolts and two rubber O rings. There is no gasket at that surface.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    JimD, thump, ........Look at your identical post up in Seville/Deville. O-rings are not forever............Get new O-rings from your dealer, pull it (the adapter) off again and reassemble slowly and carefully. When you're fooling with O-rings and flange joints, absolute cleanliness is essential. As is a new, prefilled (by you) oil filter.
